Mach Discussion => Mach3 under Vista => Topic started by: aero on September 10, 2013, 09:39:42 AM
Title: output signal
Post by: aero on September 10, 2013, 09:39:42 AM
good evening,
I have a small question
What kind of signal comes out from the parallel port when i drive a stepper?...
in other words from the parallel port we take 2 pins out for each axis (one for direction and one for step).. but what kind of signal is that?? i mean to say that direction is ccw how is the output signal like??same for steps to say it should move 200 steps how is the output like??
I need it to know how does the breakout board work
thanks you
regards
Title: Re: output signal
Post by: Overloaded on September 10, 2013, 11:45:27 AM
This .... from the manual.
Russ
Post by: aero on September 10, 2013, 02:31:32 PM
thank you very much it was exactly what i was searching for :) but i still have a query how much does the high logic level last, either for the step and dir pins??
I also have another question..
since my mobo doesn't have an internal parallel port i'm using a pci double parallel port. I use windows 7 ultimate 32 bit, however when i set up mach3 in the section: port adress, I can't find the adress of my parallel ports to insert in the text box..I search them in device manager in com & lpt but when i open my cards property there is no resource tab (I'm actually using both drivers mach3s one and my cards one)... so my questions are:
-should i use the drivers of mach3 for the parallel port or my pcis card driver??
-how can i find the adress for it??
-should it be better
regards and thank you very much
Post by: BR549 on September 10, 2013, 04:09:49 PM
First you install the driver via the cards install program. Then you install the PCI card. At that point the drivers should auto load.
Then go to the device manager and look up the installed addresses for each port.  Place that info in mach3 and away you go.
Just a thought, (;-) TP
Post by: aero on September 10, 2013, 04:53:51 PM
but my problem is that i can't find the adress in device manager because there isn't the resource tab
Post by: Overloaded on September 10, 2013, 05:03:58 PM
The DIR isn't really a pulse, it's constantly ON for one direction, and constantly OFF for the opposite direction.
The STEP pulse width is adjustable in Motor Tuning. There is also Sherline Mode which makes the duration even larger .... iirc.
Post by: aero on September 10, 2013, 05:24:15 PM
perfect that's good :) thanks... going back to the parallel port?? how can i do i also used getportadress and it says there are no paralle ports connected but I can visualize the lpt2 and lp3 in device manager?? what does it mean?
Post by: BR549 on September 10, 2013, 07:56:32 PM
That would seem to indicate the drivers did not install correctly. THere should be one for each port
Delete the drivers and then restart Windows and see IF it loads up correctly.
Post by: aero on September 11, 2013, 09:00:36 AM
so this means that i should run mach 3 and the parallel port with no drivers installed??
Post by: BR549 on September 12, 2013, 10:00:19 AM
NO I simply indicated to delete the existing drivers and let WINDOWS reinstall them when you restarted windows.
Post by: aero on September 12, 2013, 11:45:41 AM
ok understood i tryed it but nothing happened... i changed the os to xp and still the same problem.. i can't find the adress of my parallel ports
Post by: BR549 on September 12, 2013, 02:44:04 PM
What PCI card are you using?
Post by: woodspinner on September 12, 2013, 03:52:44 PM
is that a combo usb/parallel card?
John
Post by: aero on September 12, 2013, 05:32:42 PM
no combo normal pci parallel card the one of the kraun with 2 imputs:
http://www.kraun.it/pages/products/datasheet.shtml?product_code=KR.G5&language=en
tried installing drivers but nothing
tried installing drivers of W7 but nothing
tried changing port nothing
tried another pc nothing
tried on Wxp nothing
Post by: BR549 on September 12, 2013, 08:55:54 PM
The website talks about being able to remap the port address ??? You may have to reassign the address to a KNOWN LPT address.
This may be a networked LPT card that emulates a LPT and it MAY or MAY NOT work with Mach3.
Read your manual on HOW to remapp the drivers.
(;-)TP
Post by: aero on September 13, 2013, 07:40:00 AM
i'm sorry but the manual doesn't talk about remapping the drivers...
Post by: aero on September 19, 2013, 01:06:56 PM
i'm sorry for delay in answering :( but i had some problems..
however i still can't make my parallel port work....even though i tried to install drivers and tried to let them install automatically by windows but still not working
Post by: BR549 on September 19, 2013, 09:07:18 PM
Well that particular card sounds like a NO GO for your application. Try another brand.
Post by: aero on September 20, 2013, 08:33:05 AM
ok so no further solutions right?? just to be sure cause i payed it 20 euros!!!
Post by: BR549 on September 23, 2013, 12:23:56 AM
IF you are not getting resource tab then the CARD may be bad. I would return it to where you bought it .
Post by: BR549 on September 23, 2013, 12:26:52 AM
Does the DRIVER tab show up if so try doing an UPDATE to the driver. Point it to the CD that you got with the drivers installed.
