Mach Discussion => General Mach Discussion => Topic started by: Naijin on August 11, 2013, 07:03:21 AM
Hi there, after solving the PC problem by buying another PC, I have found some "gremlins in the works", I keep getting a re-set signal when running Mach3, error report shows "driver watch dog triggered" or "limit switch triggered" I can understand it if the cnc machine was even turned on but it is not even connected!!!! any one out there with any thoughts or ideas I would greatly appreciate hearing from you.
Regards
Nick ??? >:D >:D
Disable watchdogs in General Config and see if you still get errors.
Thanks for the info ger21, it seems to have worked. ;D
