Mach Discussion => General Mach Discussion => Topic started by: Simon0362 on July 17, 2013, 11:39:36 AM
Hi All,
Proceeding slooooooowly up the learning curve with Turn, I have now arrived at the next problem which I am hoping someone will instantly point a finger at the solution....
Turn is installed at 066 (full licence) operating a Compact5 PC on a dedicated PC running XP SP3.
The problems seem to have materialised since I started using the tool tables.
I always start with a 'ref all' to move the carriage (with reference Tool no. 0) to my machine reference point, referenced with opto-switches.
The symptoms are that I use Turn with one of the turn wizards to carry out some piece of work and at some apparently random point, the X and Z axes change - not so far in mid program, but either after the end or when I have stopped the program in the middle to measure or to stop.
Is this a known bug somewhere?
Hoping that someone will know what my issue is, if not I will have to delve deeper into the apparently random nature of the problem.
Thanks in advance,
Simon
PS, I would have checked the bug list but "http://www.machsupport.com/knownbug.php" now terminates on the Newfangled site with a 404 error.
Not something I could say I know the answer for as really it sounds like an offset is being called.
There are known issues with 066, especially with Turn and I wouyld definitely recommend you use an older version.
Hood,
Thanks for your response.
So far I have gone back to 062 with exactly the same results. Any suggestion which version might be be considered stable for turn?
Simon
I use if I recall, 057.
However if you have the same issue with 062 then I think it unlikely it is a version dependant issue.
If you can post your xml, your Tools3.dat and the code you are having the issue with, I will take a look and see if I can replicate and hopefully find the issue.
Hood,
Thanks for your thoughts, I confirmed this morning that 057 had the same effect which seemed to appear at the end of running a wizard.
I appear to have traced the problem to the General Config page related to the actions at the end of a program - the tickbox in "remove all offsets" was set. Removing that seems to have cured the issue.
Simon
Lots of settings in Mach that can do lots of things which you are not expecting or wonder why, the best thing to do in trying to solve a problem is try to find a repeatable way of it happening, looks like you found that way and thus found the answer to your problem :)
