Mach Discussion => General Mach Discussion => Topic started by: tbyrd0918 on June 24, 2013, 10:11:32 AM
This started just today and I don't know what is going on. Once I hit cycle start my my Z moves down to the part it is going to cut but before it gets to the piece it stops; the axis just stops moving. I can hit cycle start again without stopping the program and it will move again but then stop shortly after. I restarted Mach 3 and my computer but the problem still persisted, it even did the same thing to my Y axis twice. I've tried changing the Debounce settings, it seemed to help at first (by that i mean it moved further than it had before) but then it stopped again.
Any Ideas on what is going on???
Do you get any message in the status window at the bottom of the screen ?
I don't think so because the flashing message usually catches my attention, but I didn't look for that. I will try it this morning again and see for sure. The only thing that struck me as curious was the Abnormal Condition. It would be in Normal Condition but once I hit cycle start it would immediately change to Abnormal Condition.
Okay. So there is not message that pops up when this problem happens.
From what you describe, my guess is that you have a corrupt .xml.
If I am right (50/50 chance)...
You could either create a new profile (not as a clone of the original) and configure it (port & Pins etc.) from scratch.
or
Look in your Mach3 xmlbackups folder and choose a fairly recent (before the problem was noticed) one from there ( copy it, rename it to [your profile].xml and copy it into the Mach3 folder - backup your existing [your profile].xml from the Mach3 folder first, just to be safe)
That seemed to do the trick. Redid the XML and everything seems to be working fine!! THANKS!
