Third party software and hardware support forums. => CS-Lab => Topic started by: axilleas on May 31, 2013, 07:44:42 AM
Hello forum
I try implement the CSMIO-IP-S controller in my system (OEM). The machine
is a plasma cutter with THC. THC with a capacitive sensor.
I have the following problem.
Although THC function works fine when I disable THC function I
can only move Z axis with G00 or G01 codes once (jogging works fine).
Let me explain step by step the problem.
On Mach's default screen I press THC button.
The head moves down and stops properly.
I disable the THC function and on the MDI screen I give G00 Zxx input.
The head moves up to xx.
I press THC button on the main screen again.
The head does not move!!
After Reset we can perform again G00 Zxx for one time.
Sometimes I get "ePID fault... press RESET on MACH screen" error.
The same thing happens also in gcode. only the first G00 Zxx is performed well.
CSMIO-IP-S Firmware 2.030 (4axis, x,y,z,a slave to y)
Mach3 v R3.043.066 (NOT demo)
Thank you in advance
Cant help much with the THC as I have never used plasma but it may be worth trying 057 or 062 versions of Mach just in case 066 is your problem as it does have various issues.
do you have soft limits on ?
cause i have some issue with soft limits
SOLVED
I implemented "doOEMbutton (124)" in my M05
This resets the height corection value every THC disable.
Thank you
