Mach Discussion => General Mach Discussion => Topic started by: ironspider on May 28, 2013, 02:25:32 PM
Hello all, I just got my registered version of Mach3 and I finally cut something on my CNC which was a big moment and a huge relief :) I have a question related to my spindle though (1.5kW Air-Cooled Chinese) and the time it takes to spin up. I think this problem is pretty obvious and I think I see where it needs to be adjusted but I was hoping to get some quick confirmation and maybe a little bit more verbosity on the options (or, of course, if I'm in the wrong area altogether!).
I am using the PMDX-107 to control the spindle, it works great and takes commands from the MDI interface. The problem is that when I load a program and start it, the program begins cutting before the spindle is fully up to speed. Right now I am manually setting the spindle and turning it on via the MDI panel (using s20000 & M3 for example) and then cycle starting the program. This works but is a pain in the butt (and sort of defeats the purpose of the 107 since I have to mess with stuff instead of it all being run from the gcode)
I noticed that in Ports & Pins, the Spindle tab, there is a section for "general parameters" which lists "CW Delay Spin UP" which defaults to "1 second". Is this where I would put in something like "10" seconds to make the CNC wait for 10 seconds after the s20000 and M3 commands are issued at the top of the gcode file before it starts moving into the piece?
If so that's great and I'll change it to an appropriate number higher than "1". 2 follow ups would be: 1). why would you need a longer spin DOWN delay? and 2). What does the "Immediate Relay off before delay" checkbox do?
Thanks in advance!
Yes that is correct, you can enter your values there and Mach will pause until that time has passed before it will continue with code.
You may need a longer or shorter spin down, all depends on your machine. You also have to bear in mind that Mach is used for many different types of machines and often it is not just spindles that the spindle outputs get used for, machines like glue dispensing machines etc
The relay option is to switch off the relays immediately or wait until the delayed time before it switches the relay off. All depends how your spindle is set up, if in fact it is even a spindle, as to what you would do there. If its a VFD then likely you want it to switch off immediately.
Ah, thanks Hood. Yes, I'm using a VFD.
Okay well I'll bump that spindle delay up and check that checkbox!
Just to add a little here. Spin up, down time is often affected by tool weight as well. For instance a 3 inch face mill weighs a lot more than a 1/8 ball nose and could easily affect things. I would set the delays keeping this in mind. Hoods machines are just so amazing he never notices that any more. :)
Welcome to the forum BTW!
Ah, good to know. Thanks Brett!
In the past I tried to solve this issue editing the PP of the CAM software
Few years ago I had a modified PP for FeatureCam. A "G4 Paaaa" was automatically added after any tool change and M3/M4 routine.
The "aaaa" value was also automatically calculated by the PP regarding the S value (and of course, regarding the spindle's acceleration)
The Mach's delay values was ignored (set to zero)
I don't know if this method is "officially" accepted but it worked nice for me. The spindle was also an 1.5kw spindle driven by a VFD, modbus/brains controlled
I'm not using Featurecam anymore but I think I still have this modified PP somewhere in my (huge) backups so if somebody need it, please ask, I'll try to find it
regards,
Seb
I just set the spin up delay to 10 seconds (I'm still so new to machining that extra time isn't a huge concern to me) and now everything working great!
Seb, that is a great way to set the delay. That should work well. I think the ideal way to handle it is to monitor spindle rotation if you can and continue once at zero speed or desired speed.
^^ yeah, I agree, but I have to do more research for that :)
thanks
Hello
So, is possible to do this with an index pulse encoder for reading spindle's and a properly config of Mach3?
And no customisation of PP?
I mean, if Mach3 will be able to read the real spindle's RPM, it will can handle these delays automatically?
Where these settings should be applyed? In spindle calibration?
Or some brains should be developed?
Thanks.
Seb
Sent from my Desire Z using Tapatalk 2
Some drives have a zero speed output that would probably be easiest. You could use the index pulse and a brain I think though but that would make things a good bit more complicated. Internally mach's dwell will be tied to the delay set in spindle config. So, I guess you could set the delay to 0 and then anything you want to wait for spindle stop confirmation you would have to be sure and set it up to watch the output from your brain instead of the dwell. Also, your brain would need to be able to sense signal change, not just on or off state of the index signal because you don't know if the spindle is going to stop in a position that makes the switch active or inactive. Then, you will only be able to guarantee the spindle is below a certain speed, not necessarily stopped unless you have a brake stopping the spindle rotation.
so not as simple as I hope :)
I'll try to translate and adapt a Romanian adage: "Don't ever touch if it's working!"
so... I'll keep my custom PP which add the Dwell parameter into G-Code, which is working good enough for me :)
kind regards
