Mach Discussion => General Mach Discussion => Topic started by: BMOE29 on May 21, 2013, 09:54:02 PM
I'm new to the cnc world. I purchased a desktop CNC from Ebay along with Mach3 software. Finally got it all set up to the point where I can control the movement manually. I purchased the add on option to the basic mach 3 as well. When I select a shape to CNC, enter my dimensions, post the g-code and return to the main screen. My machine will move to the far right corner while cutting my material along the way, which isn't what I want. I would like to have the machine start in the far corner right or left doesn't matter, cut then return home. I need some serious help!
I am cutting .50 aluminum with a 0.125 end mill. I want to cut a simple 3x4 shape for practice. Thanks
Post your xml file and the gcode and I'll see if I can see whats going on.
