Mach Discussion => General Mach Discussion => Topic started by: supershepp on May 06, 2013, 02:06:37 PM
I am very frustrated at this point. i cant get my machine to find home and stay. i have two home switch installed but im trying to get one to work before i enable the other ones. i have a photoeye that breaks the beam when its home. i have set the input for pin 12 of port 1 . im using a Ethernet smooth stepper. this is what i have so far.
1. y home enable
2. denouncing set to 2000
3. when i trigger the switch. i can see it on the diagnostic page.
4. it is set to home in the neg
the problem is, when i ref all to home, or just try to home the one axle. the maching will move toward the switch. once it hits the switch, it revers direction and never stop. once it finds home, why wont it stay there?
Debounce will have no effect with the ESS so no point in having anything there. Do you have a large filtering value in the ESS config for the home switch?
where would i find that information?
Plugin Control menu then ESS Config.
