G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: Buzz64 on May 04, 2013, 08:36:23 PM
I'm brand new to machine tools and CnC. I will be taking classes in the fall (next time offered) but trying to get the 'basics' beforehand. I'll eventually be getting a 4 axis CnC capable machine pre-loaded with Mach III. (shopmaster).What are the steps (software) needed to create a 3D image and get that into G code for Mach III to use? I'm a low budget home hobbyist so don't need NASA capable software. I don't know how all the packages work together or which is best for the hobbyist. Any insight you can provide would be helpful.
Welcome to the leaning curve.You may want to explore ACAD123 as i think that is free and the correct name , and then there is a free version of CamBam but not sure if the free version will create code for a 3d file.
There is no harm in watching videos of different software to get a flavor of how it's all done.
There is some how to in this post for a project in the making:
http://www.machsupport.com/forum/index.php/topic,13398.msg102768.html#msg102768
Hi Buzz,
I was recommended GSimple ( http://www.gsimple.eu/ ) as a free starter package by a kind member of the mod team here, playing around with it for a week prepared me sufficiently that when I purchased a commercial Cad/Cam package I was able to produce working 2D engraving code on the same day as installing.
Something that slowed me down initially was tool and tool holder definition and selection, once I installed BobCad/Cam I knew the first thing I should do is define my tool holders, arbors and tools in the tool library,
Let us know how you get on,
Nick
Thanks for the heads-up, I'll check it out. This will be a slow go but by next summer my plan is to have the machine(s) and a working knowledge of how to use them. Classes this fall, winter and next spring on machines, tools and CAD / Cam. Everything depends on budget flexibility. Think I've settled on a shopmaster http://shopmasterusa.com/about-us
