Mach Discussion => General Mach Discussion => Topic started by: gtxkid on March 29, 2013, 02:03:33 PM
I have a mill setup with Mach and been having a hard time getting it going.
I think we are close but i would like to call someone to go threw a quick trouble shooting.
Sent you a PM
Thanks Brett ;D ;D ;D
You got us a lot further along. ;)
We found the wiring wrong on the Z axis servo motor. ???
It was a great feeling to see it move. 8)
Is there a setting in Mach to tell Mach that it is looking at C32 board.
Problem we are having is setting up the steps per inch but when we
give it a move command it goes a totally different distance.
There is a complete chapter dedicated to this in the manual.
Mach3 Install & Config. Guide
Up top, under SUPPORT/Documentation
Russ :)
Good, you will be slinging chips in no time now. :)
A couple of these links will help in setting up your steps per and a couple of others that you will want to check right after you get everything moving the proper distance. Also, the manual Russ is referring too really is a must read for Mach users. You will be doing yourself a favor to study it front to back.
http://www.machsupport.com/forum/index.php/topic,16315.0.html#new
http://www.machsupport.com/forum/index.php/topic,12512.0.html#new
http://www.machsupport.com/forum/index.php/topic,10308.0.html#new
http://www.machsupport.com/forum/index.php/topic,12513.0.html#new
Got it.
This is great.
We are finally getting somewhere.
