Third party software and hardware support forums. => Galil => Topic started by: sdspurlock on March 27, 2013, 09:49:40 PM
Does anyone know of a supplier for the Amp 2-5175677-9 100 pin connector? I have decided that you can grow old waiting for a cable to show up on ebay. About a third of the ICM-1900 and ICM-2900 modules have cables with them.. There must be a lot of cables being thrown away out there.
I searched the world over and there is one and only one supplier for this connector: Online Components out of Nevada. They charge $33.72 for what should be an $18-20 part. At that kind of price, it makes more sense to byte the bullet and pay the price for a cable direct from Galil.
3M makes a similar Mind D connector that sells for less than $14. Only catch is that it requires a $4500 press fixture to install it on the cable.
Maybe this is a battle that just can't be won.
Sounds like you have probably checked with Allied and Newark already. I doubt the prices wouldn't be any better if they can get them.
See if this will work for you.
http://www.ebay.com/itm/261153211002?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 (http://www.ebay.com/itm/261153211002?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649)
Mike.
Thanks for the tip, but it won't work. Bought one, but it only had 40 wires in it and few of those were ones that I need. Mostly down at the big end where the aux encoder connections live.
You might also want to search for KVAL cable once in a while. I just got one for $75.
