Mach Discussion => General Mach Discussion => Topic started by: RGCustomSignsLLC on March 24, 2013, 11:27:55 AM
I just installed a gecko g540 and downloaded the xml fromm gecko, however, i am unable to use the "reference all home" any more? i used to click the "reference all home" and it would "zero" everything out. now when i click it, it just moves the "Z" axis up?
am i missing something?
Post the xml you used before the gecko 540 and the xml your useing with the gecko 540.
Here ya go!!
There are (3) Files I am uploading:
Gecko (configured, not working properly)
RG Custom Signs LLC OLD (old file from old drivers and motors)
RG Custom Signs LLC (I took the settings from the old file that worked, and the settings from the new file that worked, and combined the two to see if it would work. It does, but now i get random "estops".
