G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: cncnoob on March 04, 2013, 08:32:12 AM
Hi.
I've recently set up my CNC for probing.
I am using the digitize wizard but getting a couple of issues.
The program runs, but crashes at random intervals and does not write the .txt file.
It records very small areas (10x10mm) but not anything roughly larger than 50x50mm.
The code then becomes corrupt and will not run again.
I have looked through the forums but can not find any solutions so far (similar issues but haven't found the solution).
I have tried to install 'probing.dll' which does not appear in my wizard or plugin setup.
Thanks in advance for any help on this!
Are you using the Wizard OR the PLUGIN ?
