Mach Discussion => General Mach Discussion => Topic started by: Jim P on March 03, 2013, 03:12:21 AM
New to cnc and nothing works and i need motor tuning help!! Once, twice maybe 3 times. :D
I have been cruising around with my demo Mach3 on my homemade unit for about 4 months now. writting simple g code and basically cutting air. I got my license copy about 2 weeks ago I guess about the same time I decided to replace the single start Acme screws with 5 start. I also replaced my home made anti-backlash nuts with some real ones from an on-line linear motion place.
With the single start screws I was running 8th steps. Everything always worked. OK, it worked as it was instructed to and the instructions may not have always been valid. I replaced the screws because the single start max velocity that worked reasonably well was 18.I was setting things on fire it was so slow I finally got around to installing the 5 start screws tonight. Set the Steps per to 3200 and here is where it gets interesting. I unmounted my steppers because everything was just buzzing and making noise. I wanted to make sure I didn't change anything on the install that caused this.
( working with inches). I could not figure out what the acceleration and velocity. I finally got the y Axis moitor to smooth out around a velocity around 750 and acceleration maxed. I think it was around. 652 . The x Axis will not run on this setting. I have to bump the velocity up to about 1000. I tried full steps and could not find a reasonable velocity that ran smoothly. I changed nothing else. Now first off do these numbers sound in the ballpark or am I way off. If someone could hold my hand and give me a Velocity and acceleration that has been pr oven to work I will try that. should I just stay at 1/8 steps or go to full.
Thanks everyone.
JimP
Hi Jim,
Welcome to the forum.
In my opinion Velocity and Acceleration are best found by 'trial and error' for each axis in turn – starting very low then working your way up until steppers stall then reducing the settings by at least 30% to achieve reliable performance.
I recommend you use your 1/8 micro-stepping rather than whole steps though.
Thanks Tweakie
