Third party software and hardware support forums. => dspMC/IP Motion Controller => Topic started by: dresda on February 03, 2013, 01:47:33 PM
When turning the MPG I have off and on signals comming in input 0 & 1 on J5 looking at Vital status screen.
DSPMC plugin set soft encoder, index 2.
Ports and pins, tick MPG#1 leave the rest blank.
No movement, Help.
hi Dresda
in ports and pins MPG setting, did you set the counts per unit to 4? mach3 needs this setting.
thanks
Rufi
the encoder is 100ppr, I set the the counts to 400?
For MPG#1 in Ports and Pins, set Counts/Unit to 4.
make sure in General Config -> Jog Increments in cycle mode, there is no empty slot. all fields should have some value, like 0.0001, 0.001, 0.01 etc.
tomorrow I will check mpg on a machine and let you know if I find any more step required to setup.
regards
Rufi
Tried it at 4 and no empty spaces for increments in general config still nothing.
