Mach Discussion => General Mach Discussion => Topic started by: Mountainman on January 07, 2013, 09:37:00 AM
OK I have a bridgeport with Backgear. Now, I am using pulley configs for that. pulley one can give me 2400 rpm @ 60 Hz @ 150 Hz I should get 6000Rpm and at the minimum of 12Hz ( 20% PWM) I get 480 rpm. Now on Pulley two/backgear I should get 673 rpm @150Hz and at 12Hz 54 rpm. Do I set the pulley configs so that both minimum settings are at 0?
all that is besides the fact that I can't get the VFD to get me the full 6000 rpm or 150 Hz. I'm running an automation direct GS2, and am awaiting their tech help to reply. Base rpm=2400 and I set the max to 6000rpm . Anyone have experience with that?
All help appreciated.
