Mach Discussion => General Mach Discussion => Topic started by: switzcheese on December 27, 2012, 12:15:54 PM
Hi. This is my first post to this forum:
I have been using the Mach 3 plasma profile. My CNC was originally set up for a plasma cutter, but I have fitted it with a router instead. I have been using it with the plasma profile and it still works fine, but I would like to configure it to work with the mill profile. I have downloaded the mill profile but nothing works with it. Do I just need to copy all of the configurations that are set on the plasma profile, or is there something else I need to do (re-licensing, etc)? Thanks
Copying your settings would suffice but also just loading the mill screenset should be all you need to do.
