Mach Discussion => General Mach Discussion => Topic started by: cornwallav8r on December 18, 2012, 08:30:29 PM
I am fairly familiar now with Mach3, have run a few parts. Next I need to engrave some printed circuit boards.
Got to the point where I can run the pcb-gcode add-on in Cadsoft Eagle, and have respectable gcode, and a decent looking board file.
But the gcode despite being told to be MAch3 compatible in the setup, won't run...it stops early on, at M3 code, and if I skip it, it finds more incompatible gcode errors.....am I missing something? some of the code follows...
(.../EAGLE-6.3.0/ulp/PCB-GCODE/pcb-gcode.ulp)
(Copyright 2005 - 2009 by John Johnson)
(See readme.txt for licensing terms.)
(This file generated from the board:)
(.../fuel flow large enclosure.brd)
(Current profile is .../ulp/PCB-GCODE/profiles/mach.pp )
(This file generated 12/18/2012 2:58:16 PM)
(Settings from pcb-machine.h)
( Tool Size)
(0.0070 )
(Z Axis Settings)
( High Up Down Drill)
(0.5000 0.1000 -0.0070 -0.0320 )
(spindle on time = 1.0000)
(milling depth = -0.0100)
(text depth = -0.0050)
(tool change at 0.0000 0.0000 5.0000 )
(feed rate xy = F20 )
(feed rate z = F10 )
(Settings from pcb-defaults.h)
(Default isolate = 0.0010)
(isolate max = 0.0200)
(isolate step = 0.0050)
(Generated top outlines, top drill, bottom outlines, )
(Unit of measure: inch)
(Inch Mode)
G20
(Absolute Coordinates)
G90
G00 X0.0000 Y0.0000
M3
G04 P1.000000
G00 Z0.1000
G00 X1.4277 Y1.7565
G01 Z-0.0070 F10
G01 X1.4277 Y1.7639 F20
G01 X1.4262 Y1.7712
Can you attach the whole of the code, what you have pasted in is fine. Also if you attach your xml I will check with it.
As Hood has said.
May be best to Zip your code (assuming it is lengthy) and add it as an attachment in addition to your .xml file.
Hmm....I am testing that code on my office machine, virtually in Mach3. Maybe it's just hanging up for some silly reason there, and will cut fine on the system. Lemme see. Thanks
