Third party software and hardware support forums. => PoKeys => Topic started by: lotusman on December 01, 2012, 07:53:52 PM
Has anyone had axis runaway using an MPG with Pokeys55?
I'm using a 5 position switch with a common ground to select axis' x, y, z & a. Position one is used for off. When I select position two for the x-axis, the indicator in Mach shows i'm jogging x & the x-axis will jog fine. However when I select the next position for the y-axis, Mach shows i'm jogging y but when I move the MPG the y-axis will move & then the x-axis starts to move & won't stop.
The MPG is connected as follows;
A - pin 1 on Pokeys
B- pin 2 on Pokeys
Gnd - gnd on Pokeys
V+ - to 5V on Pokeys
A- - N/C
B- - N/C
I used the filtering schematic in the Pokeys manual which consists of a 1k resistor in series with the pokeys pin & it is shunted to gnd through a 100nf capacitor. I tried it with & with out the filter & got the same results.
I also have a 4 x 4 matrix keypad & another rotary selector switch for the step increment & they work fine.
How did you configure the plugin? Was pendant mode enabled?
Yes
Please export the configuration so that I can see how is all configured.
NeoTO,
I fixed the problem. I wiped out all of the cofiguration files & started from scratch. I think that if you disable an input without setting the button choice back to none before you write the configuration in Mach causes a problem.
Thanks for the help.
