Mach Discussion => General Mach Discussion => Topic started by: MarkC on January 25, 2007, 10:29:28 PM
I got a Shuttle Pro and can't get Mach to recognise it. The Shuttle Pro software is not installed. Nothing works. I checked the "Reset device Selection" and rebooted. I got a "no shuttle detected of type selected" error upon next startup. This on two computers. I selected all choices in the plugin config screen. I then installed the Shuttle Pro software and everything works as it should. What should be my next step? I'm really dying to get this to work; makes my cnc conversion just like the "big guys" at work.
Mark
You need to get rid of any software that came with the Shuttle. I would suggest after you do that, reinstall the plugin. Then it sounds like you did the config right but, on the Config plugins screen you need to enable the plugin.
The Shuttle Pro software wasn't on the computer except to test the Shuttle Pro Unit. after determining that there was a problem. It did install the usb stuff when booted, but I don't think there's anyway around that. Plugin is enabled and mpg is also. Is this correct? Can't configure mpg.
Mark
Have you tried disabling the mpg? Have you reinstalled the Shuttle plugin after testing with the shuttle software?
I'll give these a try tomorrow, getting close to bedtime.
Thanks for the help
Mark
Don't use the software that comes with the shuttle.
Download the Shuttle plugin from the "download, plugin" page above and install in the plugins subdirectory
Start Mach, go to "config plugins" check to enable shuttle pro, select yellow config button and select your button options.
you'll be good to go.
Quote:
"Don't use the software that comes with the shuttle.
you'll be good to go."
Did all that. Only installed the software after trying on two computers unsucessfully to do anything. Will uninstall plugin & try again tomorrow
Still not working. Removed plugin from directory and started Mach then shut down & reinstalled plugin. Am I supposed to have MPG enabled or not? Not sure what to do next
Mark
On Diagsostics page set Jog Mode to "cont" not "mpg" a quick check can you jog with your arrow keys? if not then your in mpg mode
OK, installed latest Mach ver. MPG not enabled. Still doesn't work. Still getting "no shuttle detected of type selected" error on startup. What can I do? I'm going crazy.
Mark
Mark send me an email with your phone number and a time to call & I will walk you through the settings
I'm on central time
gary
Hi Gary,
Did you get my PM? The email address doesn't work
Mark
Yes this morning will try calling later today
gary
