Mach Discussion => General Mach Discussion => Topic started by: Mr.Horsepower on November 15, 2012, 02:28:17 AM
hi I want ask how I can make settings for laser ?
Yes I can make lazy cam code for dxf mode plasma and run and cut ok
But I want make z axle convert fire for laser beam like that then z go negative beam its start burn and if it go deep give more voltage and more power and z go 0.00 or positive beam end
Or how I get digital trigger work ?
my board tb6550 blue 4 axle
and I use relay for beam control output 1 pin 2 work ok in lazy cam in plasma mode
do I get z axes data in pin and make transitor circuit swiths run beam ?
but I make vector cut artcam pcb code and I run in mach work very good milling virtual works ok
but not work start code and beam not response z control beam start if I code run and end then code end but not lift up z axle control
Probably the easiest way to 'software control' laser output power settings is by using the Mach3 PWM signal (0 to 100%) controlled by the spindle speed S**** commands within your GCode.
This method does, however, have it’s limitations and by experimentation it has been found that a ‘stand-alone’ PWM generator controlled by Step and Direction signals and configured as a forth axis can work a whole lot better.
In addition you would also require a simple circuit to convert the 0 to 100% PWM to 0 to 5 Volts (or whatever voltage you require for your laser PSU).
What 'type' and what 'output power' laser are you using ??
laser is k-40 co2 40w Orginally.... long long time go :D
voltage you mean what I use control psu in the board ?
post prosesor if i use m3 and m5 command work ok turn on and off like plasma cutter mode its work ok
but if make code for milling mahcine turn on and off command not work but data for z axle how I convetter spindle command that
or Do I must make post prosessor ? then z go negative turn on beam and z go exsample +00.01 turn off ?
and how work digital trigger what code that need
I am out of control :D
I not sure that I fully understand your questions so I do not know if this is of any help or not.
The Z axis direction pin toggles Hi (+5Volts, or thereabouts) when the Z axis is moved in one direction and stays at that level until the Z axis is moved in the opposite direction when it returns to Low (0 Volts, or thereabouts) and stays at this level until the Z axis is moved in the opposite direction again. This signal can be used to turn the laser on / off but it does not, on it’s own, allow for variable laser power control, just on / off.
The digital trigger is probably not the best way to proceed but it can be turned on and off within Cypress Enable with the commands ActivateSignal(OUTPUT0) / DeActivateSignal(OUTPUT0) as it is essentially OUTPUT#0 and is the Digitize Output.
if I don't want use m3 code
what then else way make laser beam control ?
now I use pin 2 control laser beam and output#1 this works wery well if run vector cut like plasma cut ok
but not raster picture engrave
but if I want cut raster picture how I make setup
may can be possible My relay it too slow???
that is why this setup does not work
but if I make circuit transistor switch connect 3 wire
1 cut data
2 laser ground
3 laser drive voltage
but if I solder direct 2 pin wire (db25) and that´s connect transitor and swicts on laser beam ?
and connect transtor switch on wire 2 and 3 and this make laser beam this correct setting
If I use a digital trigger what should I do to make this works
stage by stage
of course set digital trigger on and use and inputs set what that use pin example now pin 2 in my setup
but what else...
Using a relay is not practical because of the associated delay.
If you work your way through this thread (may take some time) you will see most of the available options for laser control including using the M10P1 / M11P1 commands for vector work as well as using the Mach3 Impact / Laser plugin for raster work http://www.machsupport.com/forum/index.php/topic,12444.0.html
Hope this helps.
Okey
what it is M10P1 / M11P1 Macro or simple command ? turn on /off like m3 /m5
or can I rename m3 /m5 command and its works ?
I found your homepage and read that... gode ok
but how i get use
http://www.cooperman.talktalk.net/files/27_files/Page652.htm
but how use that step for step
or can that call example z axles gode turns on and off command
You need to use Mach version R3.043.056 or later for the commands to work correctly.
Yes, you can replace the M3 with M11P1 and the M5 with M10P1 within your GCode. These commands switch output #1 so that has to be set (Config / Ports & Pins / Output Signals) to the LPT output pin that connects to your laser trigger.
