Third party software and hardware support forums. => CS-Lab => Topic started by: Bill_O on October 19, 2012, 04:36:04 PM
I am just getting started setting up my CSMIO IP-M
With only a switch to do some testing i am not getting it to be seen by mach or the Modules Diagnostic inputs.
I can see it turn on and off on the Digital IO and on the module itself.
Have you got Mach set to the correct port and pin? I have the bigger version and that would be port 10 pin 0 in it so I assume the same in your M controller.
Hood,
I had port 10 but pin 1.
It is working now.
Bill
