Mach Discussion => General Mach Discussion => Topic started by: kolias on September 25, 2012, 02:46:34 PM
There is a difference of 0.070” on the depth of cut from one end of the X travel to the other and I can’t figure out where the problem is
On the attached pic, points A,B, C are equal to the table top on both ends and the D (Z axis plate) is square to the table.
What I should check next?
When actually cutting or when checking the table?
You need to have the table parallel to the X & Y axes full travel at all points on the table. So take accurate measurements
with an indicator locked onto the vertical support below point C and do the same for the other side and take a measurement
at each end and in the middle of the table, then mount the indicator in the middle of the brace along C. Resolve the points to a common high or low reference. Can't tell form the photos, but i would first want to know if the brace for the z axis is raising or lowering because of screw deflection.The table ideally should be flat and not bowed or twisted after it was mounted. If you had a nice long straight edge it would make things easier to do.
Actually I started to do my 1st cut on a piece of MDF and noticed that the depth was not equal. Then I mount my indicator on the spindle and noticed the same.
I do have a straight edge and the table top is flat so the problem must be somewhere on the parts of the X axis. I doubt that there is screw deflection.
I will take measurements as you say RICH and hopefully I will find the error
Sorry but my straight edge proved to be NOT so straight. Checking the table top with a new straight edge proved that the top is out the wack in numerous places.
So I removed the Aluminum top and installed a 5/8” thick MDF and now all is fine
Nicolas,
To get the best level surface, don't forget to take a surface cut of the MDF table top.
Good idea Dave,
I have a Taig spindel and the table top is about 27"x 41". What will be the best endmill to do this job?
We would generally use the largest cutter we could rigidly swing to do a job like this, normally a single point fly cutter, but I don't know if you can hold one.
Agreed with EJParrott, since you have the Taig spindle, I would personally get a 3/8" shank flycutter, and surface with that. Just take your time and don't try to take too much at once.
I will get a 3/8" shank flycutter, thank you
