Mach Discussion => General Mach Discussion => Topic started by: bad_bunny on September 18, 2012, 12:33:03 PM
Not sure what I am doing wrong. I have Mach3 running to a plasma table and in Mill configuration, everything seems to work and I get proper movement. When I try to use the Plasma configuration the motors do not respond correctly to the hot keys. Anyone else have this problem?
Steve
OK FOUND the problem.
Under Config>Ports and pins >port setup and axis selection Max NC node had Max CL Node checked and that caused the motor outputs to go weird.
After I unchecked it everything works great!
Steve
