Mach Discussion => General Mach Discussion => Topic started by: roman on September 03, 2012, 07:20:31 PM
ok i am getting my plasma table going , when i use jog keys they only run one way! on the screen it shows the numbers changing both ways but motors only go one way
Hi Roman,
First thing to check is that you have the Direction pin configured correctly in Config / Ports and Pins / Motor Outputs.
