Mach Discussion => General Mach Discussion => Topic started by: Ansen on August 21, 2012, 10:29:06 AM
I need some help with the Surfacing Wizard. There are three listed like this:
Surfacing
Surfacing Tool Down in X
Surfacing Tool Down in Y
The first one is set up in inches, but has no diagram like the other 2.
The other two are set up in mm.
I have read in much earlier posts that these Wizards should work in the units that you have your machine set up in, but that doesn't seem to be the case. Can someone please clarify this?
There is nothing I can see in the script that tells it to be metric or imperial so it is whatever you are set up in or are set up at the time of posting/running the produced code.
I see now that I was being thrown off by the default values (in mm). Since I can save MY inputs, it comes up in "inches" the next time.
Thanks!
