Mach Discussion => General Mach Discussion => Topic started by: DavidJS on August 10, 2012, 03:57:30 PM
Im pretty new to g-code have used it for doing straight forward things but now i need to cut a radius im not sure if ill need to use i-j-k its totally over my head then
Hope someone can help
David
Have a look at the G Code explanation that you will get if you click the G Code button on the main page of MachMill.
Or use a cam program like SheetCAM. Simple things usually fall within the line limit of the trial version. You would need to draw the arc, but SheetCAM will handle the GCode.
