Mach Discussion => Mach3 under Vista => Topic started by: Vegabond on July 08, 2012, 09:03:36 AM
Hello.
I see there are a few threads about the windows 7 64 bit, and mach3.
Im now changing my old computer, because i cant do ANYTHING, when i run my machine without loosing steps.
I install W7 on my old living room pc.
But i cant get the machine run.
Is there something i can do know to run mach3, or do i have to install Windows Xp ?
Thanks!
Robert.
The only way to use Windows 7 64bit is to use an external motion controller like the Smoothstepper.
The 32bit Version of Windows 7 should work fine, though.
Ok, then i will convert to Windows XP :) its just booring that i can`t use all my 6gb of ram with xp....
Greetings from Robert.
Mach3 on XP probably uses less than 1/2Gb of RAM.
Yeah, but i use AutoCAD and EdgeCAM, so i need the RAM, but i think it will be ok...
Thanks for the help :)
So how are people using Smooth Stepper with Windows 7?
The docs say it only works with 2000, xp and Vista.
Oh, before I forget, Thanks for screwing us all, Micro$oft!
I have been running my Mikini mill and Emco lathe using Mach3, windows 7 with the Ethernet smoothstepper, for about a year now. I have never had any issues with the Mach3 , Win7 and Smoothstepper combo. I built both computers myself. The specs are as follows...
Foconn mother board... http://www.newegg.com/Product/Product.aspx?Item=N82E16813186216 (http://www.newegg.com/Product/Product.aspx?Item=N82E16813186216)
Intel Celeron G530 Sandy Bridge Cpu... http://www.newegg.com/Product/Product.aspx?Item=N82E16819116409 (http://www.newegg.com/Product/Product.aspx?Item=N82E16819116409)
2 gig of ddr3 ram
64 gig SSD drive
Both computers have a second nic card installed and are always connected to my network and the internet (for updates). They also have Microsoft security essentials for virus protection.
Here's a video of it in action (the mill). The mill has been completely redone...new spindle motor, new stepper motors and digital drives, PMDX126 breakout board, Hitachi WJ200 VFD.
http://youtu.be/ucHVsttgqVs (http://youtu.be/ucHVsttgqVs)
and here are the brackets machined in the video .....
(http://i46.photobucket.com/albums/f109/slowtwitch/PB190009_zps48cfa485.jpg)
pete
My new CNC router came with a windows 8 64bit computer. It runs mach3 with a usb smoothstepper.
This is an older post, but since it came up in Google, I will clarify the details.
An ESS (Ethernet SmoothStepper) or USS (USB SmoothStepper) will run on Windows XP through Windows 10, 32 bit or 64 bit. (http://warp9td.com/index.php/faq/faq-windows)
