Mach Discussion => General Mach Discussion => Topic started by: JonGard on June 28, 2012, 04:43:47 PM
Shift in my X Y and Z axis
I am running an ACT desktop milling machine / mach 3 processor with Mach 3 CNC v 3.042.040 on a 2.83 GHz quad core processor and windows XP with a lot of services disabled as suggested by ArtSoft. The problem is the axis will shift during a machining operation. I will set the machine up to run a ¼ inch end mill at 5 in/min cutting wax, run it and measure, no problems. Set the machine up with a 1/8 end mill at 5 in/min for detail cuts, run it and measure, stars out accurate but ends up off in the x by .053in, y by .042in and z by .027in at the end. The results are never the same and is not repeatable. I have slowed my feed rate, ran a ground wire from the cnc to the computer frame and even reinstalled XP and Mach3 CNC with no luck. I have had the x axis jump during a jog. If anybody has any ideas I am desperate, so tired of cutting the same thing over and over.
Jon
Are you doing 3d work?
Hi Jon,
The problem could be one of electrical noise.
The ground wire between you computer and machine frame should be removed (this is not a good idea).
Are all your limit switches etc connected with shielded cables ??
Rich,
Yes, there is a horizontal roughing operation in the 1/8 end mill routine, but mostly 2 ½ axis pocketing and profiling.
Tweakie,
I will have to take the machine apart to see if the cables are shielded, my guess is they are not.
