Mach Discussion => General Mach Discussion => Topic started by: GAWnCA on June 20, 2012, 10:01:22 AM
Ok, I know it the older version of the ShuttlePro, not the ShuttlePro 2, may have been covered but my searches aren't finding what I need to know. I just got around to setting up MACH3 on a new PC and downloaded the plugin that is on the MACH website. I can call up the plugin to program the keys but there's no way, I can see, to program the center dial and ring. Is there a newer plugin in out there that includes these. I've been away from the hobby for about a year and a half due to health issues and now I can do some playing again. Also, can someone post a photo of what they programmed their buttons to do.
Thanks so much for your help.
i didn't think you could program the dials, surely you alter the setting in mach for different reolutions
Agreed, if you're going to change the jogging rate in Mach 3, I believe that changes the shuttle speed as well.
I don't think there's a way to program the dials at all either.
Ok, so if you can't assign them, do they just work to jog or run?
the centre is a step jog wheel and will move per step, and the outer is fast jog with seven ascending rates for each direction
lol, you beat me again! Here's a video that may help you set up the jog speed as you might like it:
http://www.seabreezeparachutes.com/sproject/7stepjogsetup.wmv
Thanks Dave, I'll keep that link for later reference.
