Mach Discussion => Mach SDK plugin questions and answers. => Topic started by: arainho on June 12, 2012, 04:46:36 PM
I managed to get a command mode plugin working, but I am now having problems with a client that is specifying a feed on each g-code line. What happens is that in this case Mach3 seems reluctant to keep sending external movements and with an end result that I get a command then about 20 empty update command and then a new command. This does not allow the machine continues movements. IF I remove the F words from the G-Code lines everything behaves as it should. Can you shed some light on this logic (I can send logs to clarify the situation) ?
Alfredo
