Mach Discussion => General Mach Discussion => Topic started by: dseaver on June 04, 2012, 09:46:45 PM
I am a new user of Mach3 and just completed my cnc router. I installed mach3
--I have successfully jogged my machine in all directions x,y,z--it homes
successfully x and y no z home switch. My machine is a gantry style with a 5'
by 5' cutting area with rack and pinion /stepper drives.Using Gecko g 540.
I have set offset location--everything up to this point seems to be working OK.
I used v-carve 6.0 --tried to cut my name --it cuts in mirror reverse. If it
was glass that I was cutting you could lift it up and look through it would
appear correct. Do I have a missed check mark in mach3 setup??? or is it not
correctly setup in v-carve.
Also the toolpath screen shows it carving/engraving correctly. As a beginner
with mach3 I can't figure this out --it's probably something checked or lefthave checked dir low active and can jog the x axis correctly left with the left arrow key and to the right with the right key.
unchecked.
I can not get the g code drawing to cut correctly from left to right. the image cuts/routs in mirror reverse.and upside down. Even though it appears corect in the toolpath window.
Looking for help and advice. Thanks in advance for your help.
Dave Seaver
Sounds like your X axis is moving the wrong way, go to Config menu, Ports and Pins the Motor Setup and change the active state for the Dir Pin of the X axis and see if that helps.
Thanks for the reply. When I check the dir low it will not home to X- --it goes to the x+ and when I jog the left arrow goes right towards the X+ and the right arrow goes the opposite way to X- when I uncheck dir low it goes back to homes to Y-, X-. It's my understanding the homing is suppose to go to y- and x-.
When I get home from work I will go through my setup again--take some notes of changes i make and report back with the results. It's not fun being a newbe.
thanks again
Dave Seaver
Hey dseaver I know what you mean as being a NEWBE. I have just learned to set up a G code, I am using BobCad.
I went to run it with Mach 3 and the tool path window shows it running but the head does not move.
I went to the config. videos and now my motor controls are all screwed up. (up/down moves A, Y moves X, Y moved Z and nothing moves Y)
The fun of all this is overwhelming.
I have 0 experience with this type of equipment, but I will get there.
Any advise?
Dave,
Did you every resolve this? I am having the exact same issue (using V-Carve). It cuts beautifully, just in reverse.
Hoss
