Mach Discussion => General Mach Discussion => Topic started by: Fred_evans on May 30, 2012, 11:04:22 AM
Sorry chaps- something went wrong with the previous post and it posted before i had finished
typing
Here is the correct post
Hi guys.
Mach3 on a lathe
My question is can a subroutine which contains parameters be called more than once but with different parameters
An example would be like tis
#1=10 ( parm 1=10)
m98 p2 l3 ( calls 02 with value of #1=10)
more code
#1=20 ( parm 1 now reinitialized to a value of 20)
m98 p2 l3 ( same sub called again but with different value of parameter)
m30
( ----eop:test prg--------)
02 ( subrourine 02)
g0 x#1 z5 (doing something with the parm #1)
da-de-da-de-da
M99 ( return to main)
Hi Fred
Have you tried it?
Yes this will be fine. FWIW you're NOT calling a sub with different parameters here. You're calling a sub where a gcode var which is global has been altered between calls - not the same thing.
If you do a M98 P2 L3 and a M98 P2 L4 - that would be calling o2 with a different L parameter and that's fine also.
Ian
I frequently use this. Ie, use parametric values to define Z movement during a circular cut, and decrease that value every time the subroutine is called. Result: helical paths for boring, thread milling etc. Parametrics can save you a lot of time and coding.
Remember that a parameter will persist between cycles ... Make sure your program resets the parameters to a safe starting point before they are called for the first time in the movement phases.
