G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: gregg on May 26, 2012, 03:41:29 PM
I need to repeat my program X amount of times for my laser to cut all the way through some materials.
Mach2 had a button for this. Mach3 does not. Is ther a way to do this with G-Code?
Need help please.
Thanks in advance.
Gregg
Call it as a sub.
hi
what cam software do u use?
u can do it by just set ur "step down" smaller than final depth
wish to help
At the end of the file instead of M30 use M47. Mach3 will repeat the G code program as may times as you let it.
Just a thought, (;-) TP
