Mach Discussion => General Mach Discussion => Topic started by: davy182 on May 08, 2012, 10:35:06 AM
Once a tool change is called the machine correctly tool changes and registers which tool is in position. It even shows the offset of the tool in the tool information BOX, but doesn't reflect it in the dro until i turn the tool offset off then on or save the tool table.
Attached is the tool change program. Do I need to put in a tool height offset off then back on after tool is changed. It used to work properly but now it doesn't. Couldn't tell you what has changed as No setting changes have been altered or new programs installed prior to the error.
I have in the top right of my program run screen these active gcodes G0, G17,G40,G20,G94,G54,G43,G99, G64,G97
My G54 offset is already adjusted to proper settings and has not been altered.
If you do recommend putting in a tool offset off and then on please show an adjusted macro with changes in red.
'ToolChange Macro For Bed type tool changer 11/05 Brian
Sub Main()
OldTool = GetOEMDRO (1200) 'Tool In spindle DRO You must add this to your settings screen
x = GetToolChangeStart( 0 )
y = GetToolChangeStart( 1 )
z = GetToolChangeStart( 2 )
a = GetToolChangeStart( 3 )
b = GetToolChangeStart( 4 )
c = GetToolChangeStart( 5 )
tool = GetSelectedTool()
NewTool = tool
'Tool Changer Macro (Bed Type)
MaxToolNum = 6 'Max number off tools for the changer
ToolDown = -6.0895 'Z Pos to Get or drop a tool
ToolUp = 0.0 'Z Hieght to Rapid from tool to tool
If NewTool = OldTool Then
Exit Sub
End If
While NewTool > MaxToolNum
NewTool = Question ("Enter New Tool Number up to " & MaxToolNum)
Wend
Code "G00 G53 Z" & ToolUp
While IsMoving()
Wend
Code "G00 G53 X0"
While IsMoving()
Wend
Code "G00 G53 Y9.25"
While IsMoving()
Wend
Call MovePos(OldTool)
While IsMoving()
Wend
Code "G53 Z" & ToolDown
Code "G4 P.75"
While IsMoving()
Wend
ActivateSignal(Output5) 'Turn On Draw bar to release the tool
Code "G4 P1.0" 'Wait for the tool to release
'SystemWaitFor (7) 'Wait for the tool Release Limit switch
Code "G53 Z" & ToolUp
While IsMoving()
Wend
Code "G53 Y9"
While IsMoving
Wend
Call MovePos(NewTool)
While IsMoving()
Wend
Code "G4 P.75"
While IsMoving()
Wend
DeActivateSignal(Output5) 'Turn Off Draw bar to Clamp the tool
Code "G4 P1.0" 'Wait for the tool to Clamp
While IsMoving()
Wend
Call SetUserDRO (1200,NewTool)
SetCurrentTool( NewTool )
Code "G53 Y9.25"
While IsMoving()
Wend
Code "G00 X" & x & " Y" & y 'Move back to where the tool change was prompted
End Sub
Sub MovePos(ByVal ToolNumber As Integer)
Select Case ToolNumber
Case Is = 1
Xpos = 9.9468
YPos = 4.0814
Case Is = 2
Xpos = 14.4954
YPos = 4.1001
Case Is = 3
Xpos = 18.9783
YPos = 4.0795
Case Is = 4
Xpos = 23.4547
YPos = 4.1055
Case Is = 5
Xpos = 27.9440
YPos = 4.1055
Case Is = 6
Xpos = 32.4681
YPos = 4.1084
Case Is = 7
Xpos = 16.00
YPos = 4.00
Case Is = 8
Xpos = 18.00
YPos = 4.00
End Select
Code "G53 X" & XPos
While IsMoving()
Wend
Code "G53 Y" & YPos
While IsMoving()
Wend
Code "G53 X" & XPos & " Y" & YPos
End Sub
Main
anyone
fixed it with an g49 and g43 at the end of the code
