Third party software and hardware support forums. => LazyTurn => Topic started by: Leadhead on April 15, 2012, 09:55:55 AM
Hi to the forum.
I am new both to the forum and to CAD-CAM. Trying to work my way through the vagaries of Lazyturn. I have produced the paths (x2) for a simple handle as a test piece. PP`d to a .tap file which I can read in notepad.(Attached) - All seems well until I load into Mach 3 Turn. A default line reports "Bad format unsigned integerLine 2"
Expect I am doing something fundamentally wrong, but have spent a lot of time fault finding to no avail. - Could anyone explain the fault for me please.
When you hit the Post Code button, you get a Code Prolog box.
Any comments in there will be posted and must be in ( )'s or it will trow an error.
Or, you can leave the box empty.
Nice looking handle :).
Russ
Russ
Thanks! That cracked it.
Spent a lot of time " not seeing what I was looking at !!!"
Rod
