Third party software and hardware support forums. => LazyTurn => Topic started by: dbvogt on April 11, 2012, 09:52:18 PM
I've drawn a 3/4 diameter 2.24 in. long clock pillar in the baluster style and want to use LazyTurn and Mach3 Turn to finish it. I'll form the 1/4 OD end parts that fit into the 1/8 in. clock plates first as I need to drill and tap them. I'm not up to doing that with a Sherline lathe under CNC so have not shown them on the drawing. I assume I must show the spigots, as these parts are called, on the drawing but how do I tell the two programs to machine only the center part? My knowledge of the relationship of machine, program and part coordinates is a bit hazy. The machining appears to be between the end of the billet and the chuck. I'll probably use a 4 jaw chuck and a tailstock center for holding and both a right and left hand bit.
Another related matter is the example of a 35 degree diamond tool in LazyTurn. I haven't seen such a shape in the 1/4 in holder size. I've got a set of Warner's holders and 80 degree HSS inserts but they don't appear to have 35? Any idea of where to get 35 degree inserts and holders, carbide or HSS? The 80 diamond's do not get fully into the corners of the baluster but a 35 should do better.
The system is timing out using Reply
Here are some images to further explain some problems. The DXF is a redrawn pillar with the “spigots” added. The major diameter is ¾ or radius of .375, the minor radius is .172 leaving a radius to cut off of .203. Assume .05 per cut so it should make 4 rough passes. Correct?
Tif 1 is a screen shot of the righthand tool setup. The left and center tools have similar specifics. Tif 2 shows LazyTurn before the rough pass is created. Note the depth per pass is .05. Tif 3 shows the first rough pass.
I’d really like Mach3 to skip any machining at the spigots as shown by the paths at these locations. How do I set up the drawing or LazyTurn just to machine in the center of the rod?
Why is the amount removed only .118 or what exactly is the .118? I didn’t find this in the manual. Why do the passes leave so much left on the minor diameter section? The second rough profile with the lefthand tool (not shown) is similar to the first but takes only .001 off. Tif 4 is the finish profile (not shown, only 4 attachments allowed) and it apparently has to take a lot off. The number of passes should be 3 but there have to be many more.
Any suggestions?
The system is timing out using Reply just for images. Here are 2.
I assume I must show the spigots, as these parts are called, on the drawing ...................
You can jimmy the start point but not the end point.
Might be best off to do another dwg including ONLY the portion that you want to machine as you do not have to show the spiggots.
I'd just reference the the face of the spiggot seat as Z0 when you set up the part.
Both LazyCam's SIM and LazyTurn insist on facing off the stock all the way to the center regardless of whether the spigots are shown or not. Unfortunately, there's going to be a live center there. Setting the start point to -.25, for example, doesn't seem to help. It looks like these sections of the G code will have to be manually deleted.
Can't be of much help on that statement other than grind your owne or check vendor sites to see what's available.
Even a 35 degree will not get into the very tight corners and you need a point tool with a radius on one or both sides such that it won't gouge the work. One should take into consideration the type of tooling to be used when designing a profile.
You can't select sections of a profile and the only way around that restriction is to use different dxf's files. Higher end programs will let you select the start and end points along a profile. Lt never went that far in development and thus it is what it is for the price.
I can't comment on some of your questions as i need to see some pic's.
I would suggest you play with the rough and fine pass settings to get a handle on the pathing. The manual covers pathing.
No comment on LazyCam Lathe and strongly suggest you use LazyTurn.
not.
Note the attached pic and first few lines of the code below as it does not face it off to the center and starts on the outside of the profile with the spigots removed.
N15 G40G90
N25 (Change to Tool: 35 DIAM 379 FLANK L -R0.0020-IC0.3790 Angle:00)
N35 T0000
N45 S402 F1.00 M3
N55 G0Z0.0130
N65 G0X4.8651
N75 G1 F1.0000 X2.8611
N85 X0.8311
N95 F1.0000 Z-2.2533
N105 G0 X2.8311
N115 Z0.0130
N125 G1 F1.0000 X0.8311
N135 X0.8011
N145 F1.0000 Z-2.2533
N155 G0 X2.8011
N165 Z0.0130
N175 G1 F1.0000 X0.8011
N185 X0.7711
N195 F1.0000 Z-2.2533
N205 G0 X2.7711
N215 Z0.0130
N225 G1 F1.0000 X0.7711
N235 F1.0000 Z-0.1147
N245 F1.0000 X0.7411
N255 F1.0000 Z-1.6765
N265 G0 X2.7411
N275 Z-0.1147
Thanks for the reply.
If the Rev: 8 Lazyturn manual is ever updated, the following could be added to the appropriate sections.
In 6.2.1 Ruler Pentagons
Note: if the graphics shows a path for facing the stock and this is not your intention, set both green and yellow icons to 0.
The Z start offset (yellow) section could use further explanation: what is it used for?
In 7.2 DXF Drawing
Note: do not show on the drawing sections of the part that are not to be machined such as spigots or additional length of the part to allow for turning centers.
Thanks for the comments, and so noted here for future updating of the manual.
See attached file.
WYSIWYG :D
Very good, thank you very much. I'll have to play around some more.
Next question. The tool code, for example "R0.0100-IC0.3750"
Is there a source that explains these codes? The ISO is a hint.
If there is ever a reason to update the LazyTurn manual, I'm available to assist.
Forget what I wrote about setting the yellow pentagon to 0 to stop facing off the stock – it doesn’t work all the time. I’ve duplicated your images (thank you again) except your very first one. LC insists on machining the spigot and facing off the face of the pillar using a left 35 degree diamond doing a fine pass. The rough pass does not do this. I’d like to overcome the quirks in LC as any alternative CAM is at least $400 and I’ve just retired. Please don’t take these comments as a criticism of Mach3 software. Mach3 Mill and even LazyCam are a great resource, a pleasure to use and I actually get things produced.
Page 28 of 50 in the manual describes typical posted info in the code. I'll update to clarify that
R is the tool tip radius and IC is the Inscribed circle of the tool.
Thanks for the offering, but don't envision much updating other than what makes sense from user replies.
It is what it is and there will be no additional development that I know of.
Frankly never use offsets much here and as said, it functionality was never tested to any great extent.
Remember WYSIWYG.... :)
