Third party software and hardware support forums. => SmoothStepper USB => Topic started by: cncezee on February 28, 2012, 06:31:52 AM
Hi Guys, this is my first post so be kind please!!
I am currently rebuilding a Newing Hall Millgrav to run from Mach3, with 4 axis control 4th being a rotary head.
I am using the Smooth stepper and high speed spindle and inverter, but… having read the threads on many forums I have made significant EMC shielding arrangements and decoupling with mains filters and moving the inverter as far away from the SS as physically possible,, we will see later if it is enough.
My question is about setting up the hand held pendant using the SS and port two, and three My pendant is identical to the circuit described here http://www.markusmechatronics.com/HandradAnschluss.jpg
On the SS pin functions page I can see the two lines port 3 changing state as I turn the hand wheel, also I can see the lines on port 2 change as I move the switches, I have configured pins 2~9 as inputs with connection 14 as above high so switches pull up lines as the switches rotate.
But how do I configure Mach3 to recognise these inputs and do something useful with them
I have tried to find the information on this site but i would be a very old man if i read every thing.....i am not too young at the moment either!!
Many thanks for your reply's
You can use various methods, set OEM Triggers, Make a Brain, use a macropump, it all depends what the inputs are and what you want to do.
For the MPG you really want to use Port 3, no just to be clear when I say MPG I am actually referring to the MPG (Manual Pulse Generator) as often people refer to the whole hand pendant as the MPG.
Anyway your MPG seems to have differential capability, in other words you have A+ and A- and B+ and B- pulses. Differential is best to be used if you have the choice as it is very noise resistant. Port 3 of the SS has 3 Differential capable Inputs so you should connect the MPG to two of them. Once you have done that you can set the Port and Pins for MPG1 to whichever Port and Pins you have connected the MPG to. Then go to Function Config menu and then calibrate MPG, you can then follow the steps to "tune" your MPG
If you need more info just shout.
Hi Hood,
Many thanks for your reply.
I mean by MPG the whole pendant, and functional aspects are basic, the knob to generate pulses, and the switches to select which axis and at what rate, like i said in my post, i can see the lines going up and down i just do not know what to do next, i have set ports and pins and set oem triggers, but then i am going into the dark, this must have been done before, i just cannot find an application to copy.
Roger
Hi Hood,
Additional information
I am using port 3 for the pulse train A+ and A-, in the encoder hand wheel two outputs are not used, port 2 pins 2~9 is being used for axis and step rate
Roger
For the encoder you must either use A+ and A-, B+ and B- OR use one of the A and one of the B channels and they must be the same polarity.
My Fault yes i am using A and B my only excuse is i am working from memory in the office!!
Roger
The just go to Config menu then Ports and Pins then MPG/Encoder page and set up MPG1 to the port 3 for A and B and set the pins you have connected A and B to. After that do the calibration as mentioned.
For other ones you would be best to use a Brain to look at the inputs you are using and to write to DROs or press buttons depending on what you want. You will need to set them up in ports and pins as OEM triggers or Inputs so you can let the Brain know where to look.
Thanks Hood
I will give it a try
Roger
Hi Hood,
I am still trying to set-up my pendant, i have so far managed to destroy the smooth stepper inputs by the dvm probe shorting to 12 volts, and subsequently having repaired the SS board i now find myself back at the beginning.
I have the A & B outputs to port 3 pins 2 & 3 pins 2 through to 9 set as inputs with select axis switch on pins 2 though to 5 and pulse speed set on pins 6 though to 8 and due to an incorrect wiring issue i have temporally set pin 9 as Emergency Stop.
on the SS plug - page i can see all lines moving with response to switch inputs, but i cannot see any indication of input signals on the diagnostic page ( ALT F7 ).. Should I ??
I can however see one input working when i hit the tap key i see the mpg speed change nothing else works. please what am i doing wrong soon i will be permanently bald!!
Help please
RH
You would only see the inputs on diagnostics page if you have them set up as inputs in Ports and Pins.
Yes, i have the port (port two ) configured as inputs but i see no leds
RH
I am meaning in Conficg menu in Mach then Inputs, you would have to tell Mach the port and pin number for each input before it would show on the diagnostics page.
You dont have to set them up as inputs in Mach, it all depends on what you wish to do, for example if you wanted one button to be a cycle start button then the easiest way would be to use the OEM triggeres. Just tell MAmach the port and pin number you want the OEM trigger set to and then you can enter the OEM code for that button from Config menu, System Hotkeys.
Below is an example of both places where you would do that.
Hi Hood,
sorry i misunderstood your statement, :-[
Yes i do have oem inputs selected and enabled
I also have system hot keys done, using numbers 259 X, 260 Y, 261 Z, 262 A, 265 JOG X0.1, 266 JOG X 0.01, 267 JOG X 0.001
only jog x 0.001 is seen to change
it is likely to be an configuration error but my analytical brain died years ago :P
If you attach your xml I will take a look.
Hood can you send me your email address i can then send you the XML i do not know how to do it hereroger.hampson@btconnect.com
RH
