Mach Discussion => General Mach Discussion => Topic started by: Machellar on February 22, 2012, 09:05:32 AM
good day all
just downloaded and installed the drill wizard for Turn and i can't get the "Cycle Type" to toggle through the different cycles
any idea what i'm doing wrong? ???
this is the wizard i'm using
http://www.machsupport.com/forum/index.php?action=dlattach;topic=16533.0;attach=23364
everything else in the wizard is working
thanks folks
Mark
Just downloaded and tried and its working fine here. Maybe try installing again.
re-installed twice more - same thing - can't toggle the cycles - wierd
i'll have to get poking around and see if i have something turned of in the settings or... maybe this Mach is different somehow
going to try the NFS Wizard and see if the drilling cycles in it work.
thanks Hood
Well
the NFS drill wizard won't let me program a feed - something's goofy here
think it's time to get a hold of MachMotion to see if there is something they can see in the Mach3 software
I wrote that wizard a while back. You are the first I have heard having an issue with it. I even did all the G-code in long hand so it should work on just about anything. Must be something with your installation.
-Wes
I think you will find it is the computer possible the display driver that causes the problem. I have 2 computors here 1 w2000 and 1 vista. The vista dawg has problem with Mach3 and wizards being able to toggle buttons and enter DROs with values. Some work some do not.
The W2000 works ALL the time. Same version Mach3 Same XML.
Just a thought, (;-) TP
this system is brand new with Win7 - that may be the issue... not sure though
is there a macro associated with the drill programs that i might not have or do these wizards use the macros?
going to try and link up with Machmotion today and hopfully resolve this
Mark
