Mach Discussion => General Mach Discussion => Topic started by: dacostad on December 31, 2006, 08:45:33 PM
Hi all, I have just finished building my CNC Router ( check it out here http://web.mac.com/dacostad ) and in the process of adding my limit/ home switches.
I have a simple question - when an axis hits a limit switch, I have to hit reset and move the axis away from the switch (I have auto override set to on). I have to reset at least twice to get it off the axis but I guess I need to change the debounce setting which is currently zero. However, my problem is that to reset the axis I have to remember what way to turn my shuttlepro or what arrow key to hit and would like to just hit a button and have the axis move away a safe distance say 1". Now I know the direction it has to move will depend on which end of the axis it is (each axis has a limit at each end wired in series, seperate pin per axis), but I figure that can be figured out depending on the value of the DRO. Is something like this possible and if so how?
David
There is a limit over ride button on the settings page. Press that and you can get off the limit switchs :) I think it is also covered in one of the video's that we have on the webpage.
Brian
