Third party software and hardware support forums. => Third party software and hardware support forums. => Topic started by: Jack Hoffa on February 06, 2012, 01:06:49 PM
I need to start a program from an exernal switch. Sorry if this is old stuff. Do I need keyboard emulator, or ???
I am working on a comercial tying machine using Mach3 software, it works quite well.
Jack Hoffa
jack.dalene.hoffa@roadrunner.com
Hey Jack, that will be easy enough if you have an input pin you can hook a switch too. Look in config, ports and pins, inputs. Assign the input you land your switch on to an OEM trigger. Go to config, system hotkeys and assign the oem Trigger the oem number of cycle start which is OEM Code 1000.
Thanks so much
Now I wonder what I can do with the other triggers
Jack
