Mach Discussion => General Mach Discussion => Topic started by: mancman4 on February 05, 2012, 11:12:14 AM
Sorry if my question is a stupid one, but i am new to CNC and hope someone can help.
I have a 3 axis Proxxon MF70 CNC, my Y axis runs in the opposite direction when G code program is run.
I have set up home switches with the following results.
Homing X - The table moves to the far right. (steps count negative)
Homing Y - The table moves away from you to the far back (steps count positive)
Homing Z - The Z drives up (steps count negative)
If i set the "reversed" to a cross on the homing / limits screen for Y axis. My G code runs OK.
But when i come to home the axes again it homes initially, but on the next command drives the wrong
way against the home switch.
I'm not sure if my Mach set up is wrong or i'm missing something in my G code.
Any help would be appreciated.
Jason
Xml attached and the first few lines of the G code:
N100G00G21G17G90G40G49G80
N110G71G91.1
N120T0M06
N130 (End Mill {1 mm})
N140G00G43Z20.000H0
N150S14000M03
N160(Toolpath:- Profile 1)
N170()
N180G94
N190X0.000Y0.000F200.0
N200G00X11.000Y10.500Z6.000
N210G1X11.000Y10.500Z-1.000F200.0
N220G1X11.000Y26.500Z-1.000
N230G1X27.000Y26.500Z-1.000
N240G1X27.000Y10.500Z-1.000
Have sent you a PM.
mancman4 - You've been given a while to respond but as you know by now if you didn't know before, you're using a pirated licence. We do not condone software theft here so this thread is now closed and your account closed. If you feel this is in error contact Mach Licencing.
