G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: turbothis on February 02, 2012, 02:47:04 PM
i cant get dolphin to do the simplest thing. ???
the preview shows exactly what i want to do. i even took out some tasks to make it simpler.
the g code it makes is useless and looks like a child just jammed on the keys. :'(
here is the code
cam
Sounds like you inadvertantly loaded some of my hand coding. ;D
Have you had this working well previously ?
Using the correct PP ?
Russ
i have yet to do anything. this is the first thing and it is chocking?
i got 4 pp's to use and they all murder it.
i am using the raidius mode on machturn and dolphin.
i would like to go incramental on the mach too. not the home thing
(http://img190.imageshack.us/img190/2006/crapa.png) (http://imageshack.us/photo/my-images/190/crapa.png/)
this is a simple 6 tool gang lathe
tool 0 is a stop and x/z zero
1 is +1.5"
2 is +3.0"
3 is +4.5"
they are all 1.5 on center.
i type in the offsets in dolphin and use only front tool post in the settings.
(http://img804.imageshack.us/img804/3710/img0425ss.jpg) (http://imageshack.us/photo/my-images/804/img0425ss.jpg/)
i tryed to use the front and rear tools too but that just dropped me in the 7th level of hell on dolphing and machturn. LOL
i have a good handle on all of the coding and such but for the life of me i cant get the dolphin to play nice. lol
I only have the demo so I cant do much here, but I get an error ...Contains invalid path.
I'll have to watch this as I'd like to buy Dolphin....if Hood still likes it that is.
Russ
i was hoping he would run over this
it seems that dolphin will make good code for turning a profile.....
well, it looks like dolphin wont print anything usefull. bummer
Licensed of course ?
That looks like the kind of garble the pirates put out.
ya, me and rodney go way back. lol
see anything worth changing on my configs?
(http://img841.imageshack.us/img841/4614/configsj.png) (http://imageshack.us/photo/my-images/841/configsj.png/)
Hood will be along, I'm certain.
Might be working for the TAX man today.
I would suspect the problem is in the Dolphin config. as the code is goofy before it even gets to Mach.
Your screen shot looks oK to me.
Not much I can do with Demo, dang ! Wish I could help.
Russ
nothing is more frustrating than this. lol
There are two Dolphin PP for Mach, one for radius and another for diameter.
Which one are you using?
Hi Rich, till he gets back. Would it make any difference between the 2 pp's if he were just drilling on the cl ?
Do you use Dolphin, licensed ? What do you think of it ? I like the looks of the demo.
Russ
toubothis attached file and see if it does anything what you want
I didn't do anything special, just used you file and posted using the diameter mode PP.
rodney gave me this one and it seems to fly.
on a side note, should i be expecting "jog follow" and "tool position" to work in the machturn?
i have a simple part that it looks like dolphin coded right.
now on the tool offsets, i have a front profile tool. this is x and z zero.
in the back i have a parting tool.
it is 7" away from the front tool and .700" closer to the chuck.
what do i put in the tool offsets to make this work?
this is all with having no tool offsets in dolphin and same front turret.
thanks for the help!!!!!!!!!!!!!!
Probably best to set that up in CAM. Might save you some editing.
Here is how it would look in the Mach tool table with your front profiling tool as the MASTER tool.
Russ
thats what i thought.
i think i am not getting the right combination of mach and dolphin.
so i found out that for some reason i have to start in my cad and go thru that to the cam. once i do this is makes good code.
if i just open up a file in the cam then is makes crap code. lol
whatever! ???
at least now i know its tricks.
thanks for the help
