Tangent Corner => Tangent Corner => Topic started by: lakeguy2 on February 01, 2012, 11:44:34 PM
I am using mach3, would like to make a simple circuit to do a repetitive motion on 1 axis, and eliminate the computer.I am using stepper motor, with drive. I have a variable pulse generator to control speed. have home switch and high end switch. thinking of starting with a flip flop rs to send signal to drive 0/1.(cw/ccw) the problem is the tool needs to stop at the home position, then restart the cycle when start is pushed. I am somewhat familiar with components and ic's I need a logical schematic. also does anyone know of a good freeware program for pcb design that can pe printed to a laser printer.. also may opt for a ne555 ic to go a specific number of pulses from home. then return to home..... any help would be appreciated, I love mach3, but am looking for a bulletproof circiut ??? to use the machine without a pc. case you are wondering it as a machine to turn a tenon on a log. so fairly repetetive, and accuracy is not a must. the only adjustment would be the length of the cut, which I was going to just use a switch, but toying with the idea of using a transistor,capacitor and a vairiable resistor (or a ne555) for the length. If you have an electronics background and are willing to help, please let me know....... thankyou, Steve
Hi Steve,
Not much background in elec., but will offer this anyway. Have you considered using one of the programmable "indexing" stepper drives ?
Parker makes good ones. Sometimes used ones are reasonable on aBey. Parker OEM 650X or 750X.
You can load complete motion profiles, very versatile.
Just an option maybe.
Russ
