Mach Discussion => General Mach Discussion => Topic started by: DICKEYBIRD on January 14, 2012, 10:04:55 AM
Hi all, new user/purchaser...trying to muddle my way forward. Great program & forum!;D
So far all of my CNC'ing has been in Turn and has been modification/repair work on existing parts with the code being handwritten from CAD drawing coordinates until I get better at the wizards and/or LazyTurn.
I have had to touch off & zero on an external feature of the parts with the x-axis zero point nowhere near the spindle centerline. The toolpath display screens on most are rather bizarre and I have trouble determining if the path "looks right" before hitting cycle start. Is there any way to offset the display screen's zero point?
Toolpaths usually look fine for me in Turn, heres an example of a random one. Can you post a screenshot of what you see and also attach the code.
Wow, that were quick!
It's cold as a well digger's behind here (by my standards anyway) and I'm waiting for the shop to heat up a bit before venturing out there. I'll post back in bit.
Don't laugh at my primitive coding; it worked and made me a few dollars. ;D
Looks similar here, what is it meant to look like?
Could you possibly have X and Z mixed up?
I don't think so. X in the minus direction moves the tool towards spindle centerline, Z minus moves the tool towards the chuck. That's correct, yes?
I just figured it was because the toolpath screen was referenced to X0 always being spot on spindle centerline. Siince this part has X0 about 1/2" away from center, it looks funny. The path was fine and the part was successfully modified. It's a model helicopter engine cyl. head "button" that needed .048" removed from the 6 deg "squish band" portion and .048" from the flange where the cyl. seats to reduce combustion chamber volume/increase compression ratio. Just a series of roughing/fine face cuts on an angle followed by a move over then the facing rough/fine cuts on the flange.
Ah Ok, its normal to have X0 on centre of the lathe and Z0 on end of stock.
