Mach Discussion => General Mach Discussion => Topic started by: Len-Tikular on January 09, 2012, 03:30:56 PM
I'm not sure if I'm in the correct area here but maybe someone can help me.
My screen shows "AXIS NOT REFFED TO NORMALL CONDITIONS'
I have inductive proximity switches on all 3 axis. (but only at one end) They work fine. I can home and ref to them all no problem. I'm just not sure what the error message means.
My machine works fine and has been for quite some time. Clearly I have something in my setup wrong.
Thanks in advance.
George
Are the LEDs at the side of the axis green?
Yep!
Al 3 boxes X,Y and Z are Green.
George
Then if everything is as it should be just double click the abnormal condition and tell it that is actually a normal one :-)
That seemed to do the trick, many thanks ;D
