Mach Discussion => General Mach Discussion => Topic started by: Xye on December 20, 2011, 03:15:04 PM
Hi. I'm so close to finishing my CNC now but i have one or two issues.
I have a UIM2901 Breakout board which seems to indicate it can control spindle speed. However I am unsure how to attach it to an inverter/VDF I have (Manual Included in attachments)
I've tried posting at CNCZone but have yet to get a reply.
Can anyone here help?
If it is not possible to control through the Breakout board and hence Mach would it be possible to make a simple on off switch and maybe a potentiometer speed controller?
(UIM2901 Manual http://www.zappautomation.co.uk/pdf/UIM2901%20Mach3%20BOB%20110718.pdf (http://www.zappautomation.co.uk/pdf/UIM2901%20Mach3%20BOB%20110718.pdf))
(Inverter/VFD Manual Here: http://chinafutai.net/en/infoview2.asp?id=4 (http://chinafutai.net/en/infoview2.asp?id=4) File is around 14MB)
BOB manual says it has PWM spindle control, have you tried hooking it up?
Not looked a VFD manual but it will have an input for 0-10v and also a couple of inputs for Fwd/Rev.
