Mach Discussion => General Mach Discussion => Topic started by: enytned1 on December 26, 2006, 12:19:51 AM
When I go to Config menu and I select Motor tuning it does nothing. I've used this extensively a few months ago to configure my machine but for some reason it does not open the window for motor tuning now. How can I fix this?
Thanks for your help,
Hi, Enytned1
Do the rest of your config menu items work / open up, if so probably the only way to fix this is to reinstall Mach3.
If not, do you have a password assigned under Operator, Lock / Unlock.?
Had the same thing happen hear once, just no Motor Tuning.
Hope this Helps, Chip
The rest of my items are fine, just the motor tuning. I don't have any passwords setup and I have never used this function.
I will try to reinstaling the software. Other than the XML file are there any other files I should backup before reinstalling? Also, how do I select different machine setups(Different XML files)?
To select a different profile you start with the Mach3 Icon rather than the Mach3Mill Icon, you can then set up a new profile.
I reinstalled the latest version of Mach3 and the motor tuning is working again. Thanks for the suggestion. The newer version looks a little different, I like it.
Amazing software, it certainly is better than the junk I have to use in my day job on those industrial machines.
Thanks again,
