G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: widpyro on November 27, 2011, 09:00:15 PM
Can someone post sample code for calling a subroutine? I would also want to quantify the number of times it repeats. Is it just a matter of typing m98 and then following it with my subroutine, and then adding L ## for the number of times it repeats, and then ending it with M99?
-jim
http://www.machsupport.com/forum/index.php/topic,20119.0.html
I cannot get a subroutine to run. I want to have the subroutine within the code. Please write me a complete example of a code with a subroutine. I need to know the order that everything should be in the code.
thanks,
-jim
Here you go
G80 G90 G55 G20
#1=3
F1
G0 X0Y0Z0
M98 P1 L5
M30
o01
G01 X#1 F50
Y#1
X0
Y0
#1=[#1+2]
M99
Thankyou! That works for me.
-jim
In general programming ( I use dbase 4 ver 2) it is possible to create a loop
which will stop when a variable reaches a certaim value.
It looks like this
x-1
do while x < 10
(do something)
x = x+1
enddo
(it will go through the loop until x= 10 and then jump out to the line
following the "enddo"
Is something like this available in Mach3 gcode??
where can i find something about it
many thanks
fred evans from south africa
NOT with MACH3 it does NOT do conditional Gcode.
What you would need to do with MACH3 is do the DEPTH value/ step depth then round UP to the next whole number. NOW this does mean you will have to start eh process HIGH to account for the roundup.
IE: Depth of 10.5mm / 1mm = 10.5 steps RU to 11. NOW figure 11x1mm = 11mm , 11mm-10.5 = .5 So you would start the process .5mm high to get to the proper depth with 11 steps.
Then just apply that to the Gcode M98 P?? L11
Hope that helps, (;-) TP
