Mach Discussion => General Mach Discussion => Topic started by: fixittt on November 16, 2011, 10:59:23 AM
Title: Another RUN FROM HERE bug with smooth stepper
Post by: fixittt on November 16, 2011, 10:59:23 AM
I did try a search...
Smooth stepper with latest driver
look ahead I have tried 20 to 200 lines
Here is what I am seeing on 3 different machines with the latest .40 mach ver registered
Create a g code with the pocket wizard.
Zero out machine and dry run g code.
press  FEED HOLD
Jog all axis`s to different location
Press the run from here button
Cycle start and I get the preparation move box
I notice that Y axis prep always has 0 in it.
on .020 with a printer port  I cannot run from here at all it puts me in the Cycle start / prep move/cycle start loop
Any ideas?
Title: Re: Another RUN FROM HERE bug with smooth stepper
Post by: fixittt on November 16, 2011, 11:11:28 AM
Screen shots
showing DRO`s  and Prep move
the forum is pitching a fit wwith uploading pics
they are out of order in the list but should go from
feed hold
jog move
prep move
Post by: Hood on November 16, 2011, 11:13:59 AM
Never had that issue with the SS so as you also have issues with the PP it may be a problem with your setup. If you attach your xml I will see if I can replicate it here.
Post by: fixittt on November 16, 2011, 11:17:55 AM
im not worried about the PP machine, do you want the SS XML?
Post by: fixittt on November 16, 2011, 11:26:26 AM
XML off off the SS box with the Y0 post. error
Post by: Hood on November 16, 2011, 11:41:43 AM
Ok will test it out later, just heading home in a few after I finish a job.
Post by: fixittt on November 16, 2011, 12:04:04 PM
just for argument sake, I upgraded mach to the .053
Still no change
Post by: fixittt on November 16, 2011, 12:49:59 PM
another test
mach 3 on my laptop...... bare install using the default xml  No plug ins of any kind.
vers .028
I still get the y0 on the prep move
Post by: Hood on November 16, 2011, 01:43:14 PM
Ok just run it here with roadrunner loaded and  then did a RFH and pressed start and prep move box had correct Y in it. Can you attach the code that you are using and also say what line you are starting the code from by RFH
Post by: fixittt on November 16, 2011, 03:34:49 PM
I think I figured it out.
RFH does not like radius commands.
I used the circular pocket wizard with X and Y as the center.  So the code had y0 in front of every line.  Then a radius off of that.
Explains why when you RFH after jogging each axis, the prep move wants to go to Y0  which does not put the tool back into the same position as when the machine stopped.
Post by: BR549 on November 16, 2011, 03:50:15 PM
You have to remember that the RFH goes back to the end of the  LINE previous to the one you stopped on. SO if that move was at the bottom of a hole THAT is where MACH will attempt to DIRECTLY go to on the restart. That is why you need to reveiw the path that mach will take BEFORE you press the go button.
Post by: Hood on November 16, 2011, 04:53:36 PM
RFH will start from the line before the one you have chosen so  that is maybe your issue?
